Does anyone know if the P38 EAS Valve driver is the same as a late spec classic version? My classic soft dash has the air pressure switch located with the valve block which I believe is the same for P38's. It would make my search a whole lot easier!
· LEGACY VENDOR
Shupack, do you know if P38 driver can fit on a first gen valve block Classic (without pressure switch on the block)?
