I made up my lead as per storey's video and plugged it in with an old laptop I had lying around... no problems... it all worked :))
Here's my problem:
My p38 in normal mode does what I call "its traffic light dance" when comming to trffic lights, and putting it in neutral or park, the back go down, front goes down, front goes up, back goes up, etc, etc. It' doesn't do this in in motorway or high modes. I suspect that one of the the height sensors is sending duff readings around normal height. causign the eas to begin to adjust itself.
What I want to know is : Can I use Storey's software if the car is running, or driving? is there a way I can get a continous height sensor read out using Storey's software?
thanks
Chain
dancing is a sign of damaged o-rings especiallt the 2 non return valves...it's a 30 minute 30 cents job to replace them ...check out /Rover Rennovations' website...better still spend $30 or so and replace all the o-rings...
cheers
