Hi, I purchased an EAS unlock cable of ebay about a week ago, it's now arrived and I had 5 minutes to play but it didn't work
The seller says they test all cables before dispatch, I also bought a USB -> RS232 adapter with it which has been tested to work with this cable.
I set the convertor up first which made the com port com5,
I went out to the car, switched the car to position 2 (radio on etc), I plugged in the OBDII Connector in the passenger footwell, I started up the software and pressed initialise. The TX then shows a 0 4 times, after the 4th time the RX responds with a "PP" and the TX shoots off doing 1, FF etc. The RX doesn't do anything else.
I've tried all the normal computer type solutions (Reboot, try another USB port etc), and I've tried cleaning the OBDII connector in the car, I've also tried switching the car on and off etc and connecting the cable at different times but I always get the same.
Any ideas, if it makes any difference the engine is in peices at the moment.
