2010-2012 Range Rover P38A
Normally I'll find my p38 in the morning with the rear down a couple inches. Just the rear. The bags are about 6 years old all around. Pump was replaced recently. All Genuine.
I just did the "leave the door open overnight" test. Suspension was left at standard ride height. This morning, no drop in the rear or anywhere.
So the self-leveling seems to be dropping the rear somehow, by mistake, as it doesn't seem to be compensating for a leak.
Super Moderator
Is it parked on a flat surface? It will self level to match the lowest corner so if parked on uneven ground it could do it.
Yes parked on flat garage floor.
Well I went ahead and rebuilt the valve block. What a difference. Suspension moves up quickly. Stays up (I think). I also will replace the o-rings in the tank collet and any others I can find.
