I have looked at Rave, and in regard to air tank, it just says remove line (that's it). I am thinking that the rubber boot might be covering a standard push in collet but I didn't want to go yanking on the rubber without knowing for sure. There is also a large nut and the Rave points to that nut in the "remove air res." section. I did search too but didn't get definative answer.
Can you guys confirm? I have a leak in either the tank or air line to the tank (most like the line, probably by the exaust...from my reading).
Thanks!!
FOUNDING MEMBER
yes, the collet is the same in the tank, the rubber boot covers it, you can just pull it back out of the way.
Are there any o-rings ( of 6mm size?) with collet in the tank?
About this Discussion
4 Participants
kultur
RangeRovers.net Forum
Full Forum Listing
