During those years, i've seen plenty of EAS problems. Maybe 100 range rover were successfully diagnosed and repaired at the shop or hundred miles away.
Thanks to this great bulletin board for my knowledge and thanks to Shupack mainly :clap:
I've never seen this case.
Symptoms are Rear Right signal incorrect, vehicle going up and down with doors open(i've never seen that).
I clear the faults, vehicle moves with doors open and goes at fault again.
Normally with a faulty height sensor or lack of height sensors, EAS goes almost immediately at fault.
I replaced the height sensor without success. Didn't do recalibration because i always try to have some luck and not being force to do it. Even with the calibration blocks it's a long job.
May you help me again?
I highly suspect the drive box or some electrical connectors near the valve block 8-|=
Flo
Flo
