My front right(drivers side UK) is dropping to the bumpstops overnight.Just starting doing it,probably due to the cold weather lately.
My thoughts are that if the RF airbag was leaking and dropping,would the EAS not lower the the other corners when the delay timer wakes the EAS ECU every twenty minutes or so during the night.I would then expect all to be on the bump stops in the am.
When starting the vehicle in the am ,the height indicator for access mode is illuminated and immediately the RF rises and the normal height light illiminates and access light extinguishes (after +- 10 secs).The system then operates normally the rest of the day.
I have tried leaving the system at other heights overnight with the same results.
Any thoughts gentlemen?
