I read the 7 page sticky, and found out others have had the problems I'm having. My car drives normally, and if I park, and come back some 20 minutes later, I find that the front of the car has raised. When I turn it on, it levels to normal height, and never does it again until I park and leave it there. I read that the non-returne valves may be the problem, or the module that goes in the valve block. My question is to the people that have experienced this symptoms: Could you fix the problem??, and what did you do??
Thanks a lot
Thanks a lot
