My wife got a hard fault while driving home today, every car issue seems to occur when she's driving, hmmmm :evil:
Anyway, I used Storey Wilsons software to unlock the EAS, you are the MAN Storey! :clap:
So then I went to read the faults and about 100 faults came up, everything imaginable including some that were "hidden". Is my EAS that messed up or is it the driver or computer that's bugging out?
BTW, after the eas was unlocked it took a very long time to level out, which is not normal for this sytem.
you have a dirty connection on plug and/or you didnt start the sequence correctly.
The video on Storeys sight is very helpful indeed and should be viewed by all
Hi,
FF's as EAS response, at RX buffer, to 1's and FF's sent, tx buffer, says that communications is working fine, as showed your screenshot.
Which are the commands sent when "read fault" is pressed ?
and
which is the response ?
Check this video from the autor of the software http://www.youtube.com/watch?v=fJaMareygYM ,though it's a previous version.
good luck.
thx storey, i´ve just ordered a eas buddy V3 ;)
Hi,
Check your COM port at the PC. Change the port on PC then change in the Software to meet the same.
Regards,
Sérgio
