Hi all,
Rather than adding to my other post on the EAS I was wondering if anyone knew which terminal on the BECM / EAS ECU signals the door and tailgate inhibit. If so is there a way I can test it with a meter to check to see if it is actually signalling the EAS ECU to inhibit. The door open signal is working on the dash so I am assuming the door units must be working or is there another output from the door outstation that I can check? If I get a signal from the BECM to the ECU it may lead me to the ongoing fault with the EAS (as per Marty's thoughts) I have covered pretty well everything else on the system.
Chris
Chris
