I have been struggling to sort out a recurring HDC and Transmission Fault on my RR.
I want to replace the compressor to see if that will fix the issue, can anyone give me a simple set of instructions as to how to go about removing the old unit and re-fitting a brand new one that I have bought?
(I know it is a bit of a drastic step to replace the compressor without knowing that it is the cause of the fault but I am not happy with the compressor anyway as it makes a bit of a funny noise on occasions when operating. I can hear it quite well as due to my LPG install it is no longer in the turtle shell).
It is very easy.
Just unplug it and unscrew.
The plugs are male female so you cannot connect wrong things.
I've got a compressor on order also... and I have lpg so suffer a slightly noisey pump. With the new compressor I'm going to leave it in it's quiet casing sticking out of the side cubby hole. Then make a carpeted box to cover it. Should make it as quiet as a mouse again.
RIP Our Friend
:think: Odd thought here, but what would the suspension compressor have to do with a tranny error? Am I missing something really obvious in the thought process?
My first thought when I read this thread the other day but thought better of saying so :wink:
Discussion Starter · #6 ·
I changed the compressor last night and (touch wood) I have not had a single warning light come on today - I've done about 100 miles today over the course of 6 different journeys, which would usually result in me getting either the HDC or the Transmisson Fault (or both) warning lights at least once if not twice. I have no idea what was (I hope this will remain a was!) causing my lights to come on but I thought I'd give the compressor a go. I would say that today is probably the only day in the last few weeks that I have had a whole day without a fault flashing up.
I am slightly concerned that I do actually have a transmission fault though because on two seperate occasions in about the last 4 weeks the following has occurred -
After driving along the motorway at speeds of 80 odd, I have slowed for a traffic jam, I have then noticed the engine to feel almost like it is low range, i.e. when I press the accelarator the engine revs but I don't move forward very quickly (felt a bit like I was trying to drive with the handbrake fully on). The engine also revved at 1000 revs on tickover as opposed to the usual 500 revs. I stopped and re-started and everything has been fine since. I didn't get any warning lights. I didn't think much of it the first time but now that it has occurred again I am getting a bit worried!
The car is booked in to LR this week so maybe they will be able to give me more info.
