Hey Guys,
Just finished re-securing the end bushing that sits behind the brushes in the end bell of the compreoosr motor. Rough noisy running and a failed thermal switch lead me to tear it down to see what could be done. What I learned was surprising.
There's a composite? ring that may serve to ease assembly by holding the brushes apart during assembly and then lives in the compressor from then on. It eventually wears down the crimp indents that secure the bushing cage plate into the housing. When this happens the bushing cage plate slips out and allows the bushing, plate, and ring to wallow free, eventually damaging the connections on the backside of the brush card.
I cleaned up the bush and fittings, re-oiled the felt, and re-pressed the whole assembly back into the end plate then gently peened over the edges, in four places, to re-secure the bush cage. The bush is free to align itself in it's cage/socket, but won't freely spin. I didn't include the composite ring in the reassembly. Thus eliminating the chance of future wear and failure. :thumb:
Here are some photos of the project:
Bad bushing and plate, loose and free to travel out of center.
Drilled press fit pins and removed brush card.
Another shot of loose bush and plate with brush card removed.
Bush components. Bush, oil felt, cage plate, composite ring.
Bush cleaned, oiled, installed with oiled felt, and cage plate pressed and peened into place.
Back together. (Yeah, I broke off one of the fitting screws :doh: , it'll hold.)
Commutator...
Holdong brush out as you "walk" the end bell back onto the commutator/shaft.
Ohm reading across brushes after assembly. New brushes.
Commutator...
