Hello,
I have a P38. In the normal height suspension drops every 30 seconds, then climbs back up. The compressor is therefore almost all the time ON and I worry that it'll die. Currently I drive into the lower position.
I assume that the problem is in the front sensors for height. Am I right?
Plan A: I try to perform calibration on a little different height for normal ride.
Plan B: If I'm not going to buy new sensors.
Problem: I have a cable from ODB II to RS232. I installed the EAS Unlock Software. I can't connect. I am constantly getting RX signal 80 and 26, which would mean that the link does not work. I've already checked:
- The cable and the connection pins,
- I changed the ECU suspension unit (I have two of them)
- My colleague also recommended to change comma and decimal point in Windows language settings.
- Switched left and right front sensor -> after this it’s even worse. The compressor is always ON in every height of the vehicle.
Still doesn't work...
Have any idea?
Even if I got o plan B, I will have to buy new sensors and I will have the same problem. Or calibration is not needed?
LP
Have any idea?
LP
