I have never cheked mine it's a 96 with 117,000 i have just relied on the Air dryer doing it's job.
It is part of a service check but if you dont have any of the software or cables you could, i think lower the vehicle to it's bump stops then slowly release the drain plug as i am told it does have a groove in the plug to allow air to be released slowly BUT BE WARNED there is a lot of pressure in the reciever and i do suggest you get the software and cable of Storey wilson this will allow you to de-pressurise the system safely then you can inspect it if not and you don't feel confident take it to an inde garage and get them to do it.
IIRC the plug is on the end rather than the bottom so without takign it off and turning it on end I am really not sure how much you would gain.
