Are there any sources for a new RH/passenger-side front turn signal in solid orange for 87-91 trucks? Part is PRC6164 I think. Thanks all... just getting start on an RRC after years of Defender adventures.
Buy another one for spares...
Not sure on sourcing, but when I am in such positions I always buy a set. INstall the new set and keep the stray piece on the shelf. Purchasing a single marker light will leave you with a bodged look as one will be nice crisp and clear and the other will be scratched and foggy from age and road sand blasting. THis is also a great change to change styles should you choose.
Buying a set is my problem. One side is available, but the other is NLA and I don't think the later model year part number will work.
I was under the impression that all 86 onward turn signals were the same for fitment. Only the colours changed depending on market.
Has anyone tried fitting the later part? If they are all compatible, then PRC8947 is available and would work.
Really not a bad idea...A buddy just bought two RRCs for $400.00, one was purely a donor, while the other is a runner with decent bits. I know others that have more than one donor/parts truck to keep their RRC healthy.
