Need help with my 2004 Range Rover HSE 4.4L
After sitting for 2 weeks I started it and pulled out into some traffic and had to accelerate with About 50% throttle, it took off well until the TAC reached 3300 rpm and Then acted as if it Electronically rev limited..I let off the throttle and it shifted to second perfect.. got back on the throttle and same story rpms limited at 3300 so I let off and perfect shift to third.. same story to forth and 5th. No check engine light.. vehicle runs perfect under full or partial throttle until 3300 rpms is reached. If placed in park and neutral revved the same thing happens rpms limit at 3300.
