My serpentine belt broke this winter. Struggling to remove the fan clutch and about to take my saw all to it and install an electric fan.
Anyway, the dynamic stability pump appears to be frozen. I knew that there was a leak in the rear sway bar, added fluid for a while and at some point it ran dry enough to lock up so that is my bad. So, I am looking at several parts (that do not seem to be available used) that will total what? 5K?
A little about the truck, it is a 2006 SC Sport with 90,000 miles. I bought it knowing of the leaking sway bar among other issues. But, I paid $9400 a year ago so figured I could spend quite a bit to get it running – a new battery and air tank on eBay and I drove it home. Had I fixed the leak it would have been worth it, but now that I have damaged the pump the entire system likely needs to be replaced. Considering that I couldn’t tell the difference when it was working and empty, I likely do my tearing around in my BMW (as it should be) and not in the truck so thinking it is a luxury I can do without.
I am wondering if there is a means of deleting this pump in order to get it running again?
