Had a problem with my battery going dead and I took it to a Range Rover technician and he informed me that the DVD player was the culprit and this was causing the battery drain. His only solution was to disconnect the DVD player, which did stop the battery drain. My question is will purchasing a new DVD player be the only solution to the problem long term or is there another possible fix to the problem. Thanks.
2009 Range Rover L322 HSE
JACK'S GRANDAD
Use the search first.
When you get the massive amount of hits, go through and see which is the same as yours.
Follow the post through.
This site is more aimed at helping folks help themselves.....Thus the search function.
Martin
