1 - 1 of 1 Posts
Hi and good evening,
I actually and since a week own a RR Supercharged 2010. Everything with the car is working fine. But I have one Problem/ question.
The DVD-Charger/Player is playing DVD, but only until the DVDs Menu. Then it is possible to push the Buttons on the touch sreen but nothing happens. Same happens when I like to change, for example from one DVD to the other. It seems that the Signal from the touach sreen is not arriving at the DVD-Player.
I called RR Luxembourg and also RR Germany, but no one knows such a Problem. I also changed all fuses which are in relation with DVD or Entertainment, but no new result
Someone has any solution for this issue?
Thanks a lot for your help.
Best regards
Bernhard
1 - 1 of 1 Posts
