Hi All,
Issue number 2. My My2010 RRS has RSE installed. But when i insert DVD insto the changer in the boot, i do not hear any sound of them loading, the eject button works fine. When i try to play i cannot play neither on the main screen nor on the Rear screens which only say DVD error.
Any suggestions? or it as simple as it sounds? The changer is not working?
Maybe it's a bad disc... Try loading the magazine with 6 DVDs. When you do, the DVD changer should scan through them for several seconds - you should physically hear the noise of the changer working through the 6 discs. If you hear nothing, perhaps your changer is indeed not working. Are you sure you are loading the disc with the label facing the right way in the cartridge?
I did pop in a magazine with all 6 disks but i didnt hear anything. The discs were all working in another RRS and on the diagnostics it shows DVD fault so the more it think the more its pointing to the changerThanks again for the suggestions
