Dust in headlight lens - can I remove lens w/o removing entire unit?
Recently purchased a 2010 Range Rover HSE and there seems to be a good deal of just inside the headlight lenses. Outside is spotless but inside is dirty - any idea if I can remove the headlight lens w/o removing the entire headlight unit?
Not sure about 2010 headlight construction but on previous year range rover there are clips all way around headlight glass that need to be unclipped and to do it the only way is to take the headlight unit out.
But on your place I assume your truck is under a warranty and I would make that a dealers headache as the headlight must be immaculately clean inside no matter what. I assume seals might me bad and needs replacement. So if you still have manufacturer warranty, call LR
