I apologize in advance for asking where is the oil filter on the 06? (Jag engine). I can't find it! Second: my range has 40,000 miles I am second owner I think brake pads and rotors are original. I checked today and the pads are ready for replacement. There is no shimmy on the brakes at all so since I do not have a micrometer to measure the rotors would you think they should be replaced or just leave em? TIA, Dave
After some more digging here is the answer from the Atlantic British website diy area:
And this is why I couldn't find the filter: It's under all these shields!
Range Rover 2006-On (Jaguar/Ford Engine)
Filters & Parts
* Oil Filter - By Mann (Part # LR007160)
* Oil Filter - Genuine (Part # LR007160G)
* Oil Drain Plug with Washer 13mm (Part # 1005593G)
* Oil Filter Wrench - Fits Filters 2-3/8" To 3-1/8 (Part # W300)
Installation Notes
* You will need to remove the under engine shield and the radiator splash shield to complete this change.
* Oil changes are best done with the engine just warm, not hot.
* A specialty oil filter wrench (our part # W300) is recommended for installation.
* The Oil Drain Plug on this vehicle is integrated with a plug gasket. The plug and gasket should be replaced with each oil change (our part # 1005593G)
* 1. Raise vehicle to access the under side of the engine. Support vehicle safely -- vehicle ramps or lift recommended.
* 2. Remove the six bolts securing the engine under shield.
* 3. Remove the tow ring cover by releasing the four clips revealing two screws.
* 4. Release the front spoiler to reveal the four hidden screws beneath it.
* 5. To do this, use an 8mm socket to remove the two screws just below the license plate. Then remove the 6 screws using a 10mm socket. Release the spoiler and remove the four "hidden" screws behind it.
* 6. Remove the remaining 9 screws to release the radiator splash shield.
* 7. Position a suitable oil drain container to collect oil and remove oil drain plug using a 13mm box wrench. Discard old drain plug.
* 8. Position a suitable drain container beneath the oil filter. Remove oil filter -- filter wrench (part # W300) recommended.
* 9. Replace the oil filter. Install new drain plug and tighten.
* 10. Lower vehicle and fill with 8.1 qts. of 5W-30 oil.
* 11. Start engine and idle until oil pressure lamp goes out. Check oil level with dipstick and top-off if necessary.
* 12. Reinstall removed engine under shield and radiator splash shield.
