Hi All,
it still never ceases to amaze me that the members of this forum are able to assist with solutions, so here's a conundrum for you.
I have managed to get a pair of safari 5000 driving lights, but the rear swivel mounting brackets are missing from both. I've, tried to, attach an image of what I mean.
I have a bush bar and am getting the metal mounting bracket to mount them on, but how do I replace these, somewhat, essential bits.
I’d welcome suggestions
Dazzle me
[attachment=0:2994x3bj]Land_Range_Rover_Discovery_Defender_Safari_5000_Lamp_B.jpg[/attachment:2994x3bj]
Yep... you can buy some square steel tubing at the hardware store and massage it until it fits. If you can find the right size, all you'll need is a couple drill bits and a hacksaw.
I ended up in the same exact situation as you! I will take a picture of what I made - it's far from perfect (or pretty) but it will hold them on there. Essentially just an L bracket is all you need. If the bracket is sturdy enough then it shouldn't sway side to side, and a U bracket will allow just as much front to back movement as an L shaped bracket. I am going to order these http://www.roverparts.com/Parts/STC8814G.cfm from atlantic british - lamp steady. Or just make some.
HI All,
thanks for the quick response. I will classify these in the "get your finger out and do it yourself you lazy....." category.
I will try and have a go at the weekend. Do you think Aluminium would be OK. The lights are not that heavy
For the steady bars, I am working on that also. I thought some threaded Rod tapped directly into the light itself
Thanks again...
Funny you should mention the spotlight shake.
I thought i would have this so bought a set of steadies for the lamps.
In the end i tried without and get no shake at all.
Not sure if it's because i had the nudge bar brakets over engineered when they were fabricated instead of the stock brackets or the rig is too smooth.
