Can anyone recommend a tool out there for extracting the drive shafts and replacing them , got stuck again trying extract the rear shaft to replace the top and bottom bushes.
Now I have damaged the end of the shaft and the nut wont go on . I have the whole hub and shaft off but my press is tool small to allow the shaft joint in through the frame of the press.
Wary of a puller used on the hub as it may separate the hub bearing fro housing.
That’s great I’ll have a look , curious to know if it refits shaft and by pushing it out , does it have you noticed the hub flange move under strain with the pulling pushing effect.
The items you highlighted are not very accessible on the net but still searching!
Ok Thank you ,cannot open on this phone will try on microsoft at home
