Status
Not open for further replies.
2000 p38 American country 4.0
So the window switch started acting up and worked intermittently just on the drivers side window. All the other windows worked fine. I got a new switch and installed. Now the window won't seem to remember the "set" position after some time goes by.
I get the message window not set, and fully open and close the window and get the window set message.
However after about 20 min with the engine running or whenever the engine is turned off it shows the window not set message again...
Any thoughts why it won't remember it was set? I'm at a loss. After it's set it functions normally until it just stops working and the window not set message appears again
At a loss why this is happening...
The thread talked about the connector for the door wiring harness behind the a pillar trim. Wondering if they actually meant the upper a pillar trim or meant the kick panel?
They were talking about the door wires and I don't think the go up the a pillar do they? Makes more sense to me to be behind the kick panel on the floor under the dash
Status
