I searched the forums but could not find the answer to my issue, I am a new owner and still trying to learn the functionality of some things. My doors are set to auto lock at speed, when I park and go to exit my drivers door will not open unless I hit the unlock button. When I pull the handle nothing happens when locked, is the drivers door supposed to work like this? If I pull any of the other handles the door will open without having to hit the unlock button.
No, that's not normal. You should be able to open all doors from the inside without unlocking them first, even with auto lock enabled (the one exception would be the two rear doors, with child lock manually enabled on each door.)
Thanks for the response, it is still under warranty so I will take it in. I also have the annoying headliner squeak/rattle that they can address while it is there.
