2000 P38 4.0
My driver side door latch is sticking (outside). I have to push it in the last 1/4 in. It works fine...if I replace it, can I keep my lock? Will the dealer have to reprogram it?
Both fan relays were melting in fuse box. I read the post...I replaced the pollen filters and put in two new relays. Everything worked well for one month...today one of the relays started to melt. Will the dealer need to reprogram something if I replace the fuse box? Is there anything I should check out first?
Thanks for your advice..this is a great forum!
