1 - 1 of 1 Posts
Hi Guys
I’m hoping for some help on my 2004 hse l322.
The issue is that I have drive for a few yards then then nothing - if I turn the engine off and back on again it get drive again but only for a few yards !! This doesn’t work all the time !! I’ve had a garage look at the electrical side of things and at everything is ok there. They sent it to a gear box centre who have said in there opinion I need a reconditioned box at nearly 3k . The garage have said the fault codes were coming up with a problem with 3rd and 4th gear. I have been reading the forums and the discussions around the shaft spline being a common fault ?? Which would give the same symptoms as my problem. I have basic mechanical knowledge - do I believe the gear box firm and bite the bullet and purchase a second hand box ?? If I do this will I need to replace the oil cooler as well as replacing the oil and filters!! I would appreciate your knowledge and thank you in advance for any input / help and advise.
1 - 1 of 1 Posts
