I know where the freeze plugs typically are on a vehicle, but before I go to the trouble of sliding the transmission back. Is there a freeze plug behind the engine in between the engine and transmission? My rover is leaking out some coolant and I would like to either replace the corroded freeze plug (if it exists) or push it back in. So I don't have it dump out while I'm driving (my luck, it would be while I'm going to the mountains on that windy road in the winter with nowhere to pull off :? ).
Also, it only leaks when I fill the coolant to the "cold level" line. Once it leaks out a certain amount it stops... Has anyone else experienced this?
