Pretty sure the PAS fluid is the original and I want to replace with fresh. Is there a drain plug or an easy way to get the fluid out?
It's messy. Pull off return hose and stick it in a container. Have someone start the car. You need to pour new fluid in as the old fluid is pumped out. Shut the car off when you see new fluid coming out of the return pipe. Re-attach return pipe top up level. Bleed system by starting and turning the wheel back and forth a few times. Then re-check the level and you're done.
Thanks Locky....
Admins, please add a thanks button as they have on AULRO.com `)
