Discussion Starter #2
Drained front differential, where is the fill bolt?
I found it on the outside facing side of the transfer case, behind the driver side front wheel. It was an 8mm hex vs the 14mm hex drain bolt. Took about 0.65 quart of Mobile One Synthetic Gear Oil 75-90. Much better than the brown mud that was in there.
Re: Drained front differential, where is the fill bolt?
When you say "took about" did you fill it to top of fill hole? If so that's incorrect and it's overfilled. The proper procedure is to replace whatever amount you drained from the differential.
