I bought my RRS with rear right doors that did not open or close using either remote or dash. I had to do it manually by pushing/pulling door knob.
After some reading I decided to replace door latch. After replacement, which took a noob like myself a while, I put everything together, closed the door and realized the door would not open from the outside. I went inside and opened it and afterwards everything started to work as expected. I could use outside door handle without any issues. All good, so I decided I will set child lock back...
Next day I couldn't open the door. Outside door handle doesn't work. Obviously I can't do it from the inside as well because of the child lock.
I can clearly hear the door mechanism when locking/unlocking using remote. Door knob opens/closes as expected. I'd say outdoor door handle somehow lost connection to the latch, but it is strange that the same thing happened just after replacing the latch and it was all good afterwards.
Any ideas on what could possible happen? Is there any method to unlock my doors (to at least get rid of the child lock?). Is it possible to remove door trim panel from the inside? - looks feasible but it could be tight. Or maybe it would be easier to simply unscrew door hinges that are visible after opening front doors and take the whole door off to disable child lock?
