My 1993 RRC SWB needs new window trim pieces: the part that clips onto the window sill and sandwiches the sliding glass on all 4 doors - fuzzy on the glass side, rubber squeegee on the outside.
Is this part interchangeable with the trim piece on a Discovery 1? I'm having difficulty finding this part as a RRC-specific piece from the usual vendors (RN/AB/LR Direct).
1995-2002 Range Rover Classic
it is called the window channels, try land rover direct but to answer your question, yes the d1 or d2 will work.
Thanks, I learned a bit more, including another name for the part: waist seal.
Part numbers are MXC8014/8015/8016/8017 (one for each door).
Every vendor I can find lists these as no longer available, so I need to find out if D1 parts are a direct fit. If worse comes to worse I can pull the parts off of my own D1 to experiment, but I was hoping to get a definitive answer before resorting to that.
Since you have a D1 why not just measure them first. Maybe Will Tillery knows the answer.
Please update when you find out... I could use new ones too.
