Hi all
The rubber seals that are fixed to the body of the RRS and act as a weather seal when the doors are closed are starting to come loose (adhesive has failed) in some random areas around the top of the doors. This is made more apparent when the doors are closed as the door frames pull down on the seals.
They aren't completely detached yet so i as thinking of re bonding them but don't want to use something that would damage the paint if they ever need to be removed.
Anyone have this issue and DIY fix it without having to fit new seals ?.
Carl
Carl
