3 of my 4 door panels have started to come loose from their attachment points. Enough being enough, I've started by pulling the rear door cards. The glue has completely broken down and no longer bonds the plastic attachment posts to the door card material.
Does anyone have a suggestion on what adhesive to use for the repair? This is a fairly simple repair, but I realize the wrong adhesive could release again in the heat of summer or the cold of winter. Looking for any advice on what has held up for other people.
Mine had same issue. I used SuperGlue Gell as it was a fast, one time solution. Another option could be standard 'Contact Adhesive' where both surfaces are coated then allowed to dry before mating together for an instant bond.
use a heat gun to reheat the existing glue. it works!
