Hey there- I'm new to the forum and Range Rovers.
I just purchased a '95 RRC LWB and so far I love it.
One small problem. The passenger door lock "sticks" and doesn't unlock when unlocking the doors from the driver's door. I don't have an alarm fob either! The previous owner said if you time it just right you can unlock the driver's door, get in, unlock the other doors using the passenger lock and "Bob's your uncle".
This technique is hit and miss at best. Sometimes I can get the doors unlocked but the alarm sounds when I start the engine.
Later today I will remove the door card and clean/lube the actuator. Hopefully this solves the problem.
Does anyone know a way of disabling the alarm and still have the vehicle drive able?
I wasn't sure if the alarm was stand alone or if it was controlled by the ECU or the like.
Any tips or trick regarding the locks or alarm would be greatly appreciated.
Thanks in advance for any guidance!
Cheers!
Cheers!
