My driver's side door lock and door handle do not function properly when the truck has been sitting in the sun for some time.
If the door is locked when the car has been sitting in the sun, two things happen:
-- The lock does not respond the lock/unlock button.
-- The inside and outside door handle stop functioning. It's as if it's become disconnected to the internal components of the latch....no resistance whatsoever when pulled.
Has anyone ever had the same problem?
2006 Range Rover HSE 4.4
Discussion Starter #2
Problem solved!!! Well...not really solved...simply ordered a new used latch actuator from eBay. Using a few videos from powerfuluk's youtube channel I was able to successfully remove the door card, handle and actuator.
