So, whenever I disconnect my battery for whatever reason, it takes couple of months for my key fob to resynch. As everybody knows, it's most likely the door latch failing, that's causing this problem.
The main culprit, as I understand it, that causes the latch failure is the microswitch. There were couple of posts about replacing just the microswitch, but haven't seen any details about the kind of part, as well as sources for the microswitch.
Are there any experts out there who knows what kind of microswitch is needed? Perhaps a part # so I can order them up through Mouser?
