Another question about this old '99 4.0 SE with 188,000 miles. I've put on a used door lock actuator to solve my "Engine Disabled" issue (the remote wasn't being picked up by the car and it wouldn't let me start her up. I couldn't use the 1-5-1-5 code)
Anyway, now I'm getting the "Front LH-Door" Open light / buzz on the dash... even when the door is closed.
Is this an issue with the new/used actuator or something else?
Mike
That is your actuator not recognizing that the door is closed. Sounds like you received a duff unit. I would return it for a working unit. You should also be having issues with being unable to use the remote to arm the alarm adn your EAS will not work.
