Hi
I cant move backward uphill.
It does not climb a cerb backward.
Gear R is becoming useless day by day.(60.000miles)
I changed oil and reprogrammed 2 months ago.Any relation?
The symptoms of the 5L40E (GM tranny) are identical, you place the car in reverse and it revs up like in neutral and does not move. is stated;
Mine moves unless it is uphill(backwards).Is this the same situation?
There is a low pressure and high pressure loss of reverse in an article.
My situation refers to high pressure loss since occurs uphills i guess.
Any comments?
A specialist offered to change selenoids and try since there was no metal in the pan and oil was ok.
But i think i will have to rebuild it.
If the fluid looked okay (i.e. no sign of a mechanical failure in the running gear) then presumably the worst-case fix would be a replacement valve block?
Phil
