A buddy of mine had an LR3 (06 to 09 roughly) and has the stock 20" rims still and would essentially give them to me for spares.
Was the offset acceptable for use on an L322, assuming they are the same bolt pattern?
Sent from my Pixel XL using Tapatalk
Can you ask him to look in the wheels to see what the offset is? I couldnt find a 20" oem wheel for the LR3 only 19". They all have offsets of 53 and 58 which would work and you could go lower.
Turns out they are stock 19" rims off an LR3. Anyone know what the offset would be vs. my factory 20" on my 06 SC? 19" should clear my brembos?
SUPER MODERATOR
LR3 and Sport rims are interchangeable. Since Sport rims fit on L322s you should have no issues. See the sport section for what size rims fit over what year Brembos as not all Brembos are the same size.
You need to put a picture up of the wheel. There are different styles of 19" LR3 wheels but from the all of the styles I have seen, they go from an offset of 53 to 58.
I have LR3 wheels on my 04 RR. The prior owner would buy used wheels rather than new tires - was cheaper from the wrecker. They should fit, and some model years offered the exact same wheel for the RR and LR3.
