I'm thinking/hoping the answer is yes but can someone in the know confirm before I make a massive mistake.
I've got a 2004/2005 v8 autobiography with the 20" BBS alloys and need to get them refurbed. Will the 18" wheels from a vogue fit if I buy them as a second/spare set?
Many thanks in advance.
For the first gen L322 20 was optional, 19 was standard, we never had "vogue" over here but none of our rigs came with 18". If you have some low spec of first gen L322 that came with factory 18 rims then they would most likely fit. I don;t believe brake sizes changed between models because Rimmers only list one part number for pads/rotors.
They will fit, the Autobiography trims did not have any sort of performance package for 2002-2005.1, so same as the base SE that came with the 18s from factory.
