Just wondering if anyone has completed this part of the "maintenance" for thier Range DIY style instead of the stealership, states in RAVE that you are in need of T4/Testbook if your doing the flush instead of the topping off or bleeding...
Ive done pads and bled lines, but im wondering what the "steps" are that RAVE is referring to that T4/Testbook has...
anyone? anyone? buhler?
I've done the fronts fine on my '03 Vogue tonight, no issues.
good job on "doing the fronts" on your rig, but im asking about a fluid flush/change. Complete system/front and rear fluid, not pads and rotors, although I probably wouldnt attempt the fluid without doing the pads and rotors at the same time.
Im wondering if its possibe to drain and then refill the brake system/lines without T4/Testbook, anyone done that?
yes, it's possible. but if you get all fluid out I'm not sure of.
When I did my back pads, I did bleed the brakes and and filled with new brake fluid when doing the bleed.
