Good evening all
New to the forum and new to p38 found browsing the forum
Most interesting and I'm sure one of you will be able to help me , just fitted new track rod and I'm looking for the basic dimension centre to centre of the ball joints as the wheels seem to be toeing out
Thanks in advance
Every rig is going to be different due to wear, assembly differences etc. As toe is the only alignment possible the cost is much less than full alignments... at least around here. You can also grab a buddy, place a 2x4 across each tyre parallel to the ground and measure the distance between them front and rear to do a rough alignment.
