If you are serious about swapping headlights consider the Rangerover Sport lights. The size looks much better.
996TURBO said:Any photoshop master on this board? 8)
Thanks.Tango said:996TURBO said:Any photoshop master on this board? 8)![]()
A very very quick and poor attempt, gives the general idea though.
Find me some big high resolution pictures of your rig and a disco 2 head on that I can use and I'll be happy to combine the two properly so it looks a bit more realistic. I'm somewhat lacking in pictures of disco 2's
I got them for salenipper said:If you are serious about swapping headlights consider the Rangerover Sport lights. The size looks much better.
I already have HID Bixenons inside those. That lights the darkness like daytime :twisted:viperover said:Just my 2 cents, replacing all 6 light bulbs with the Osram silvers stars make a big difference.
The Gems engine mod on alty is a must, run a thick cable from alt to battery direct and three things happen.
1 Brighter lights
2 You automatically double up your starter cable, in effect the starter turns alot quicker
3 Shorter cable = less voltage drop to battery keeping it in its ideal charge state
Nice but as you've done, the bonnet needs attention.lrscott said:How about this...
996TURBO said:Arg, i add an offer on a set of 2006+ xenons for L322 for almost half the price of one P38 OEM headlight.![]()
It may end like this if i take my time do it neatly 8)
Wish me good luck 8)
I have to disagree with you there. The RRS lights fit worse - which is why you see all these conversions done with FFRR 06-09 lights, too. And I've had both in hand to compare as well. The hood (bonnet) does need reworking which wouldn't have been a problem for me as I already have a bent bonnet corner due to a close encounter with a treeviperover said:RR3 sports lights will fit and look better as I've had a pair to compare, bonnet corners dont match so I dumped the idea.
