Dipping mirrors when in reverse. Put the car into reverse and the mirrors both dip, go back into forward, the drivers side comes back up but the passenger one dose not. Go into reverse again and both dip, and so on. End up with the drivers fine and the passengers looking at the road. Then have to bring it up with the switches. Where should i look for the fault? The motors within the mirror are working and the gear lever is sending the lift command. I have got the dip mode off at the moment.
Land Rover want an arm and a leg to look at it.
there is a way you can disable the dip function when you put it in reverse it,s in the handbook how to do it i,ve disabled mine had the same problem .
Mine dip at completely different angles, you can disable it by putting the car in reverse and them pressing and holding the seat memory button untill the display reads mirror dip diasabled
Yes, They are disabled at the moment. Its just that they are handy, even better when you've got a trailer on.
I would like them working, but not at great cost.
The feedback potentiometer in the mirror could be faulty.
