Hi guys,
Has anyone had any success with repairing a diesel viscous fan?
My range is over cooling and the fan is very stiff (when the engine isn't running).
Any advice would be appreciated
Many thanks
Surely it's normally fairly stiff when not running ? Problems usually happen when the viscous doesn't lock up and the fan slips. Also is the thermostat working properly ?
The problem is that the water temperature in the engine and the heater core only gets to about 40dc which in my thoughts can only be the fan over cooling (unless someone will correct me)??
That's why engines have thermostats! To restrict coolant circulation to the engine (fundamentally) until desired operational temperature is reached when thermostat opens to allow coolant to pass through the radiator.
Check your 'stat in a pan of heating water with a thermometer and see how it behaves. My guess is you'll find it stuck open.
I will agree my fan locks when hot and never overheats or underheats, but an open thermos and no heat. Use distilled water only with antifreeze I learned my lesson.
