1 - 11 of 11 Posts
Hi, I am thinking of returning to Range Rover ownership after a two year absence :D , but this time going the diesel route. We do a lot of motorway miles, so what sort of mpg can I expect if I fix the vacuum pipes and have the cruise control set to 70 ? It will be auto, two passengers, light luggage. Also on the latter models are the water pumps the steel impeller type, rather than the plastic exploding type? Thanks
I also get around 28 mpg on a long motorway run with my chipped DSE.
I have a full bullbar, winch and large spot lights on the front which causes extra drag. I estimate this drops it by 1 to 2 mpg.
Have you thought of the LPG option?
I get the equivalent of 31.5 mpg in general driving conditions (based on buying LPG at 50p/litre compared to unleaded at 104.9/litre). On a long motorway run, I'm getting the equivalent of 36-38mpg. The conversion was done 70k miles ago and there have been no problems or other costs other than an annual LPG service to change filters for £45.
The other advantage is that you can actually accellerate on a cold morning.
With lpg, you can't carry a spare without much hassle and the short range due to a small tank can mean frequent fill ups.
with my p38 diesel manual i could get around 28-30 mpg on a good long run, when giving it some stick i could generally only manage 15-20
Mine is a Diesel Auto, road biased tyres and nothing bolted on outside.
With A/C working hard it goes down to about 28MPG, without A/C I am very disappointed to get less than 30.
1 - 11 of 11 Posts
