Diesel 300tdi Removing the Injectors - Hitting the firewall bulkhead
Hi
I have the leaking injector issue with the copper washers.
I'm quite happy to do the job my self and I have removed all the necessary parts and have 3 of the injectors out.
Trouble is the 4th / last injector at the back of the engine is under part of the body work and I simply can't get it out at there is not enough room.
I take it someone must of done this on the Range Rover classic before and found a way, I can only think of two options, one is bashing the little lip that is on the firewall, but I'm not to keen on that.
The other is dropping the motor? maybe remove an engine mount?
Has anyone got any ideas for me, I see it's not an issue when they are fitted to other Land rover bodies.
Look forward to any ideas or help
Phil
Discussion Starter #2
Re: Diesel 300tdi Removing the Injectors - Hitting the firewall bulkhead
This is where the issue is
some better pictures
