Im planning on doing a coolant flush and change this Easter wknd. Is it better to use demineralised water for the coolant mix for the radiator?
Any other cooling system tips?
Cheers.
Yep, distilled water is best. The less stuff in the water besides water the less stuff there is to react with and corrode.
Don't use a radiator flush chemical, just water. My nephew used to use those flush chemicals on every new/used car he got. A couple of months later he was replacing leaking freeze plugs. When he stopped using the chemical, he stopped losing them.
we have moderately hard was here, and I must admit I have always just stuck the hose on it and filled and flushed that way. Then again due to lots of very hot weather I have my radiator rodded every 25,000 k's anyway......
My well water is darned near sea water. (The valley I live in was once a salt-water sound, and the ground water under it partly sea water. Think of Washington's Puget Sound, then add a quarter million years.) I use jugs of distilled water I buy at the store for my radiators. It's cheap. Using it is also cheaper than repairing salt corrosion in the cooling system.
Scott
Thanks for the input.
I flushed the cooling system, all the coolant that came out was clean. I refilled with water and took for a 100+ km drive with the heater on to flush the system and again the water was clean, no rust or sludge. I did the final refil with a 50/50 mix of Nulon Long Life Concentrate Coolant and demineralised water.
How often should I service the cooling system? The bottle of coolant says it lasts 5 years or 250 000 kms, which ever comes first but that is probably far too long?
Most of the cars I own recommend every three years, but somehow my cars always need some repair that requires draining the coolant before that happens.
Scott
